Old 06-15-2005, 11:19 AM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
does your engine perform better with, or without the O2 sensor??
just womdering, cuase i installed a heder, and forgot to put in the o2 sensor, i had it connected later, and car seems to run slower, is this right??
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 06-15-2005, 11:57 AM
Hybrid1990crx's Avatar
Re: does your engine perform better with, or without the O2 sensor??
yeah, its gonna make your car throw a code. I ran my 89 si without the o2 hooked up for awhile cause the o2 sensor was sending a bad signal and making my car bog, its also going to make you run really rich and use more gas.
Old 06-15-2005, 12:03 PM
and just out of curiousity, did you forget to put the o2 sensor into the bung on the header or just forget to click it into the harness, cause I'd think you would be able to hear a huge exhaust leak as soon as you started the car if you forgot to put it in the bung.
Old 06-15-2005, 01:54 PM
Re: Re: does your engine perform better with, or without the O2 sensor??
when i installed my header, it cam bith a bolt, in the header where the sensor goes, i just trew out the old one, its was all cracked and wires were coroded, so i said ill eventually get a new one, picked up a new one from work, and seems a bit slower now
How can you find out if the O2 sensor is even working??
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 06-15-2005, 02:23 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Maybe get an Air/Fuel gauge and hook it up...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-15-2005, 11:30 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
did you clear the code?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-16-2005, 12:14 AM
a/f guage aint gonna do shit unless you have a wideband
dont forget to reset your ecu now too since it was probably throwing a code for it before.
Old 06-16-2005, 08:33 AM
I just meant to see if he has power going through the circuit... I guess a voltmeter would work too
2010 Honda CR-V EX
