Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 06-15-2005, 09:16 AM
SlamminMOfo SlamminMOfo is offline
Rear LCA Bolt Sizes
Hello,
I have a stock 1993 Civic EX (no mods at all) and it was due for a new set of rear shocks/struts. As it happens often, the shock mount bolt was seized and destroyed the bushing. I ordered some aftermarket LCA's with the bushings installed already to avoid the headache of having new ones pessed in the OEM arms. What I need to know is this:
Does anybody know the exact bolt sizes for the rear lower control arms. There are three on each side. I believe the shock mount bolt is a different size than the bolts that hold the control arm in. If anyone can provide me this info, I'd appreciated it.
Thanks!
Old 06-15-2005, 07:50 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Rear LCA Bolt Sizes
Originally Posted by SlamminMOfo
Hello,
Thanks!
You guessed right...
The shock bolt is as follows: BOLT, DAMPER (10X84)
And the other 2 bolts are: BOLT (LOWER) (10X80)
Make sure you replace them with at least grade-8 quality bolts or higher. Grade-8 is considered automotive quality. Grade-10 you might want to get if you can. The bolts that Honda would sell you might be best as I believe they are case hardened as well. If you get them from a hardware store, make sure they are zinc plated, otherwise steel bolts will rust like a mother on there. Remember, the torque pressure on those bolts is about 44lbs. of torque for each.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 06-15-2005, 09:43 PM
Re: Re: Rear LCA Bolt Sizes
Thank you, SilverY2KCivic. I will try to get the best quality if possible. I did call a local Honda dealer and they quoted me $9.72 per bolt! YIKES! The guy even felt embarassed telling me that as he started of with "you may want to go to a local fastener store...."
Old 06-16-2005, 12:21 AM
Cali Guy
Re: Re: Re: Rear LCA Bolt Sizes
haha, yeah. Dealer isn't the best place to get that type of stuff from. But anyways, no prob.
hessemer69 on AIM
Old 06-16-2005, 01:35 AM
BullShifter's Avatar
Re: Re: Re: Re: Rear LCA Bolt Sizes
www.hondaautomotiveparts.com
Old 06-16-2005, 08:10 PM
Cali Guy
Re: Re: Re: Re: Re: Rear LCA Bolt Sizes
Originally Posted by jackasssi
I was going to link him to that originally, but the shipping would make it pointless sicne you'd pay almost as much for it as the bolts. He's better off at Lowes or Home Depot for them.
hessemer69 on AIM
Old 06-19-2005, 10:52 AM
Re: Re: Re: Re: Re: Re: Rear LCA Bolt Sizes
Thanks for ther reposnses...
I have another question... What type of nut(s) should I get? (no pun intended) Flange nut? And what should be the Metric size of the nut? I'm not sure of the exact sizes so please bare with me on this. Also, should a washer be used with the flange nut?
