Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-15-2005, 02:10 AM
UnderEstimate Me's Avatar
UnderEstimate Me UnderEstimate Me is offline
Prelude S Vs. Si Vs. Vtec
Hey, I am currently in a little argument with a friend over the three prelude models offered in 93 through 96. I know that there is a difference of thirty horsepower between the three, but I cant find the stock quarter mile times for any of them. I have heard the Vtec prelude can pull of a 14.9-15 flat, but i dont know if its true. Does anyone know the et's for these three different cars? Thanks a lot.
2005 Neon
Stage 1 PCM l K&N CAI l Mopar rice plate l 3'' TBE l Spring mod l PB shift knob l Mopar strut bars F&R l ACR sways l Tokico Shocks/ Tein Springs l Ricey wing removal l JMB Catch Can l QW FMIC l Autometer WB l Diablosport Predator
Old 06-15-2005, 10:26 AM
Retard324 Retard324 is offline
Send a message via AIM to Retard324
Re: Prelude S Vs. Si Vs. Vtec
i think the Si does 15.9 and the S does 16.3
'93 Nissan 240sx
'90 Nissan 240sx - KAE-T? might go NA instead
Old 06-15-2005, 11:53 AM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Between the 3 there is a 55 hp difference. S-F22a1-135 hp. VTEC-H22a1-190hp.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 06-15-2005, 01:03 PM
Gohan Ryu Gohan Ryu is offline
15 flat for a VTEC is being generous. It's more common for a stock VTEC to run mid-high 15's.
Old 06-15-2005, 01:51 PM
V T E C H's Avatar
V T E C H V T E C H is offline
maybe this site will help...
http://www.albeedigital.com/supercou...0-60times.html
It may be a little off, but should give you a general idea, if you car is even in there.
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-15-2005, 03:42 PM
Re: Re: Prelude S Vs. Si Vs. Vtec
Well dont the last generation of preludes run like 15.2? I thought that since its the same motor and the 96s being lighter, i figured it would notch down the time a little.
2005 Neon
Old 06-15-2005, 04:22 PM
jono828 jono828 is offline
the 5th gen actually ran like mid 15's. 4th gen preludes vtec run around 15.3 quarter mile times.
Old 06-15-2005, 04:41 PM
Actually the fastest I've seen posted for a stock 4th gen VTEC is closer to 14.9 (don't remember exactly). 15 seconds is possible under ideal conditions with a perfect launch and good shifts. It's just more common to run slightly higher times given that not every run can be a perfect run.
Old 06-15-2005, 08:23 PM
Yep, a good driver could yield mid/low 15s. An exeptional driver might be able to pull 14.9-15.1 or close to it. But most drivers aren't going to pull 14s with a stock lude.
dSoc member #67
Old 06-16-2005, 01:30 AM
Alright...so if I could get an Si to about 190hp, then i can hope for mid to low 15s as well?
2005 Neon
Old 06-16-2005, 02:19 AM
Gammey3's Avatar
Gammey3 Gammey3 is offline
92 Si w/Header-Exhaust(removed cat.) & Cold air intake : 15.4
Old 06-16-2005, 10:31 AM
Alright so what would you probably need to do to get an Si in the high 14s? Is there anyway to do it without touching the internals? Thanks a lot.
2005 Neon
Old 06-16-2005, 01:06 PM
You're talking about shaving nearly 1 full second off the 1/4 mile with just bolt-ons. I'd guess you could come pretty close if you do all of the bolt-ons - CAI, header, hi-flow cat (or none at all), good exhaust, pulleys, cam gears, flywheel, clutch, ECU etc...
My guess is with all of the bolt-ons you'll add 20-25 whp, possibly a little more...depends on how well you do the tuning. But that doesn't seem like enough to shave a full second. Maybe an LSD to help with the launch.
You'll get better results if you lighten the car - remove AC, power window and sunroof motors...if you do enough lightening and all of the bolt-ons I'd guess mid-14's.
