Old 06-15-2005, 01:16 AM
speedphreak speedphreak is offline
painting/airbrushing interiors
Hey guys/gals....I did a search but didnt come up with what i wanted. I am wondering if anyone airbrushes their interiors, and what paint do you use? I am doing some VIP cars and I am wondering if some of u even paint the interior of the VIP cars.
-Chris
Old 06-15-2005, 01:45 AM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: painting/airbrushing interiors
I just use spray cans for the interiors. No primer or any prep. Just glue and spray...
Old 06-15-2005, 02:03 AM
Jaymes.............what paint exactly do you use....no primer? How does the paint stick?
-Chris
Old 06-15-2005, 02:38 AM
Jaymes's Avatar
Most of my interiors are black. I use Krylon Semi-Flat Black. I guess it is a little more dull that Semi-Gloss or it may be the same, but I think it gives a satisfactory texture that simulates a black leather interior.
Of course I tend to rush things. You may want to use the airbrush if you have custom colors in mind and you can't find the spray paint. You can prime if the interior plastic is different from your color in mind, but I don't think priming is necessary if the plastic color is similar or the same. Some people do not prime their car bodies when using Tamiya paints. Just be careful that the paint isn't too hot and crazes your plastic
Old 06-15-2005, 12:28 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I use just Tamiya and airbrush it.
-Mike
Old 06-15-2005, 12:30 PM
Vric's Avatar
Vric Vric is offline
I like using ModelMaster Acrylic Flat color for interior / airbrush
do use primer
Old 06-15-2005, 01:03 PM
The model master water based paints? Or just the regular...I find water based or water borne paints a PITA to shoot out of my eclipse!
-Chris
Old 06-15-2005, 07:00 PM
Vric's Avatar
Acrylic = water based. It work grat in my Anthem
Old 06-15-2005, 07:16 PM
LS1Aaron LS1Aaron is offline
I generally airbrush everything,and avoid any brush painting.If for no other reason its smoother than a can even on interiors.If your having trouble airbrushing acrylics something is wrong,especially using a good airbrush.
Old 06-15-2005, 09:17 PM
OK, tomorrow I will be heading to my lhs. I will pick up some Tamiya acrylics. I am going to use a Iwata HPC airbrush to do this. Do I need to primefor these paints...and how about thinning? And what pressure should i spray these at?
-Chris
Old 06-16-2005, 10:24 AM
g00eY's Avatar
g00eY g00eY is offline
i usually spray paint the tub one color(usually some sort of black) and then brush paint everything else.
Old 06-17-2005, 10:16 PM
Get you some rubbing alchohol and thin the paints about 50/50,to the consistency of milk,spray at 20 to 25 psi.Its that easy,and acrylics are very forgiving.
