Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-14-2005, 08:07 PM
wht97EclipseGS wht97EclipseGS is offline
97 2.0 Eclipse not starting
Hello, new to the forum. Was wondering if anyone has any ideas on a problem I am having with my Eclipse. It starts and drives fine for about a week, then won't start. I am able to get it started if I unplug the MFI relay then plug it back in...starts right up? When started this last time I used the key method to get the code via the check engine light and the code is 43. Any ideas on what this might be or where to start with diagnostics? Thanks in advance for any input.
Old 06-16-2005, 09:41 PM
macder macder is offline
Send a message via MSN to macder
Re: 97 2.0 Eclipse not starting
Please put your vehicle information into your signature since it makes it easy to identify your car. Looking @ the thread name, and your username, I'm assuming you have a 97 eclipse GS.
Code 43 - SRS warning light does not light.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
