Old 06-14-2005, 07:50 PM
gigglesnirt's Avatar
gigglesnirt gigglesnirt is offline
Send a message via AIM to gigglesnirt
need some help from someone that knows a little about small engines?
i need some help, i've got a honda oddysey go kart, and its been running kinda shitty lately, the problem is i can get about 2 laps around the track, then it starts to lose its rpms when i hit the gas, if i let off, the engine kinda idles a little, then i will try gas again and it will sound like its about to die, i've tried many things, at first i thought it was old fuel, but it wasn't it, im just not sure, your help would be great.
btw its a 250cc 2 stroke engine, only one gear so no tranny if it helps.
Old 06-14-2005, 08:06 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Sounds like somethings wrong with the carb. I don't really know, but I know my go-cart had tons of carb problems.
*Under Construction - New sig to debut*
Old 06-14-2005, 08:13 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: need some help from someone that knows a little about small engines?
yep. My 4-wheeler did about the same thing.. turns out I had a blown head gasket.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Andydg Andydg is offline
Since it's 2-stroke I would check the plug they tend to foul pretty fast in 2-strokes. A carb. problem would make it foul faster than usual...check to make sure the float isn't sticking.
Old 06-14-2005, 09:06 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
Send 'er my way and I'll get her running awesome. Actually for school we did take apart mower engines and I got a big ol' 8 horse briggs and we completely tuned them up, and dissassembled them and such. I'd take the previous guys' advice and replace your spark plug and try tuning the carb a little bit.
We had kids bring in their go kart engines and take a pipe, braised the threaded fitting from the muffler onto the pipe and then stick those on there, we had some very loud little engines.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 06-14-2005, 09:10 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
Check the piston for carbon build up. I think after 25 hours a 2-stroke will need its piston cleaned of carbon.
Also, you could check your oil to fuel mixture. If you have to much oil it'll foul your plug pretty good.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 06-14-2005, 10:58 PM
its not the spark plug, i have tried 2 different ones, but i just kinda gave up and we're taking it to the honda dealership tomorrow so no worries!
Old 06-15-2005, 11:59 AM
mysatilac's Avatar
mysatilac mysatilac is offline
I posted in AF In General that Small Engine Repair should be its own small forum here in OT or somewhere else,
But my advice would be to run some B-12 through it while you've got it at a high idle, it'll sound like its gonna die, rev it up a little higher
It'll burn up the carbon in the combustion chamber
Make sure those spark plug are gapped right too
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 06-15-2005, 01:33 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
It sounds like a fuel starvation issue. Next time it tries to die, let it idle for 15 or twenty seconds - and then it should rev without hesitation - at least for a little while.
A clog in the fuel filter, or a clogged gas cap vent both sound like likely problems.
Carbon build up takes a long time - the 2-stroke engine in my subaru requires decarbonization every 5000 miles (or more depending on how you drive) the faster and harder you drive it, the less often you need to clean it out. Carbon build up also signals it's arrival for many, many miles before it actually reaches the point where the engine will barely run.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 06-15-2005, 07:17 PM
in your first sentence 2 stroke, thats a lot like what is happening, it will almost die, then i will let it idle for a little bit, and it'll give back some power, and i'll be able to get it back to the garage without pushing it, but i im not able to run it consistently at all or it will die.
