Old 06-14-2005, 03:21 PM
rruddfan21 rruddfan21 is offline
Rear disc brakes
How easy is it to convert the rear drum brakes to disc? Do you simply remove the drum assembly/backing plate and then replace it with rotors? Also, what is the benefits of this? Thanks in advance.
Old 06-14-2005, 04:49 PM
chembrad chembrad is offline
If you do it the way I did it, then the job is simple.
Just go to the boneyard and find a Suzuki Swift. Drop the rear strut assembly and disconnect the brake line. It is only two nuts to drop the strut, one nut/bolt hold the vertical pin in the axle and one nut holding on the rear arm.
You also have to pop off the clips that hold the brake line on. Next unscrew the handbrake housing and unhook the cables.
Under the car gently pry off the rubber seals that attach to the body where the cables enter into the compartment.
Once you take them off, you can see exactly how they will go on.
Two things to consider:
The wheelstuds are not the same on the Swift (they are 12mm as opposed to 10mm on the Metro).
The Metro wheel will not fit on the rear disc brake.
I picked up a set of 16" rims with Yokohama ES100s 205/45 ZR14 87w. HAHAHA! They look awesome.
'05 Dodge Grand Caravan 105k miles
'94 Geo Metro 1.0L 5spd 185k miles... at least I can fix it!
Old 06-14-2005, 06:40 PM
mik13usa's Avatar
mik13usa mik13usa is offline
Re: Rear disc brakes
To help with Chembrads answer, It is pretty easy... if you have all the pieces. No it is not just remove drum and back plate, you need a new knuckle and bracket for the caliper. The only benefit that I see is the ease of maintenence. They do NOT drastically improve braking, but like Chembrad said they do put you into a different wheel stud size. ALso a good upgrade at the time ( if you decide to do this) is a stainless braided line kit. They DO make a difference in pedal feel and responsiveness.
Old 06-15-2005, 11:54 AM
OOPS! my tires are 205/45 ZR16 87w
I'm not sure if they rub yet on a tight turn or bumps, but they look good!
Old 06-15-2005, 11:56 AM
Also my friend shagpal came over and had the strut/brake assembly and showed me how to do it. THAT made the job extra simple.
