Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-14-2005, 02:50 PM
sean820 sean820 is offline
replacing r12 system 88 98 regency
I just cant figure out wich valve is the high and low side so i can finally get some air conditioning in my car
Old 06-21-2005, 07:23 PM
diesel1962 diesel1962 is offline
Re: replacing r12 system 88 98 regency
Greetings.Are going to convert your A/C system to R134? If you are,The low pressure fill port would be located near the reicever-dehydrator.It is the can shaped silver object,Located near the firewall.There will be a refridgerant line coming from the compressor to this object.Look for a plastic cap,Then unscrew this cap,There you will see the low pressure fill port.Good luck..Diesel 1962
