Old 06-14-2005, 02:44 PM
turbo ES turbo ES is offline
COMPUTER which one?!!!
i took my dash apart and setting horizontally there was a 8*8 inch box aprox. and then there was a box vertically behind it a little that looked almost identical but had diffrent plugs which one is my computer
Old 06-14-2005, 04:05 PM
Re: COMPUTER which one?!!!
the vertical one has a lot of corrosion so thats whats causing my problem but what is the other one they both go into the same harness?
Old 06-14-2005, 04:32 PM
Igovert500's Avatar
blue + red light magnet
I'm not sure off the top of my head which is hte ECU, but if you check www.stealth316.com
There are links to follow to check out the ECU, so the directions would tell you. Just look under the Garage section.
Also I'm guessing the other box is your TCU (tranny control unit)
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-14-2005, 05:05 PM
ok thanx
