Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-14-2005, 12:51 PM
noholdsbarred noholdsbarred is offline
boost leak, ignition
hey guys, i got a 1994 laser awd. The car was kinda "stumbling " at higher RPM's. I recently replaced the spark plugs (ngk) and air filter and is still doing the same thing every now and now then. The spark plug wires were replaced about a year ago. It's bad when the car is cold or raining outside. Could it be an ignition problem or a boost leak?; which I haven't checked for yet. Any help would be appreciated.
Old 06-14-2005, 07:12 PM
joemathews's Avatar
joemathews joemathews is offline
Re: boost leak, ignition
Could be either, but I'd bank on a boost leak, since your ignition parts are so new. Do a boost leak test per VFAQ.com.
1996 Eagle Talon
