| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
The check engine light on my '95 SE indicates problems with the knock sensor and the rear O2 sensor.
Any ideas on how not replacing them affects performance/operation? These bastards are expensive to replace!! |
Those two codes go hand in hand a lot. If your car is not running correctly (tune up time, dirty air filter) you may get excessive ping. The knock sensor detects this and retards your ignition, making it run rich which causes your 02 sensor to go out of range, throwing the 02 code as well.
Make sure your car is in good running condition first. Check your plugs, air filter and gas filter. If everything is in good shape, change the knock sensor first. Your 02 error code will probably go away after that and you'll be shocked at how much more power you will get.
![]() 99 SE LIMITED - A few changes here and there but most of all SPOTLESS! |
Thanks for the info.
As you said, I'll start with the knock sensor. Everything else you mentioned (plugs, fliters, etc.) were replaced last May. |
Hey NJMAX
What kinda wheels do you have on your max?
99 Max SE Limited ![]() APEX'i Cat Back Exhaust PIAA Super Whites Clear Diamond Cut Bumpers Cleared Rear Corners H&R Sport Springs KYB AGX Adjustable Struts & Mounts |
Re: Hey NJMAX
I like those!
