Old 06-14-2005, 11:16 AM
CHEVY1 CHEVY1 is offline
2000 Chevy Astro Won't Start When Wet Outside?
Hello
I have a constant problem when weather is damp or raining my van will not start until the engine compartment becaomes very warm or hot and dry. Once the sun warms it no problem. I have had the enghine light in the past come on and off, but it hasn't in a long while and bthe vehicle still does what it does. I have been told it is wires, or a distributor cap,maybe an ignition problem. Any help would be greatly appreciated.
thanks
Old 07-13-2005, 08:42 PM
davegarman davegarman is offline
Re: 2000 Chevy Astro Won't Start When Wet Outside?
Originally Posted by CHEVY1
Hello
thanks
I had a similar problem with my 97 Astro, may I suggest that you do a FULL tuneup with cap, rotor, plugs and plug wires. If that fails to correct your "won't start when it's damp out" problem. Try replacing the coil. I live in Ohio and the problem only occured when it was almost cold enough to freeze outside and DAMP. The new coil finally did the trick but the other things must be done too! -Dave
Old 07-19-2005, 10:56 AM
bthiele bthiele is offline
I also had this problem on my 97 Chevy it was the coil.
Hello
thanks
Old 10-24-2005, 09:36 AM
G8wood G8wood is offline
Hmm, I did all those, including the coil, still a no start when its cold/wet out.
Old 10-24-2005, 12:05 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
I would check both the connections to the battery and the connections to the starter after the battery has been disconnected. Does it tick? Or do nothing? There should be 3 wires to check on the starter.
Old 08-28-2006, 12:26 PM
sykesr8 sykesr8 is offline
How was this problem fix. I am having the same problem with my 2000 Chevy Astro
Old 08-28-2006, 12:41 PM
Blue Bowtie's Avatar
Registered Offender
Same problem? Including the error codes? If so, scan the PCM and it may point you in the right direction.
Old 09-09-2006, 11:45 AM
ceevester ceevester is offline
One thing I have learned: don't assume the new electrical parts you install are good.
If your problem remains, go out at night and crank the engine and see if there are any sparks "leaking" out.
Use the water spray bottle technique, and squirt the electrical parts,(distributor, wires, COIL, etc) and see if you get a stray spark start to leak out.
I had this problem, and with "The Old Masters'" help, I did this techique, and found a cracked "new coil".
I replaced the "new coil" with another "newer coil", and my problem appears to be solved.
