Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-13-2005, 11:39 PM
sayedawg sayedawg is offline
Question 99' Whinning noise
have 99' E.B. with a auto-trans, 2wd and V8. Just got the car from father due to health reasons. ? is that the vehicle makes a LOUD whinning noise when it reaches 25+ mhp..trans shifts and pulls fine. I think the noise sounds like it is coming from the rear differential / axle area. The closest thing I can compare the sound to is heavy equipment transmission (backhoe. etc..). Any thoughts on what this may and help would be great...trans fluid is good, tires are good...
Old 06-20-2005, 04:06 PM
anthony1978 anthony1978 is offline
Send a message via Yahoo to anthony1978
try draining all the old fluid out of the differential and putting in new fluid. if this does not work the bearings or the pinion might be loose. hope this helps you.
Old 09-14-2005, 12:12 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
I had the same problem, it was a bad planatary gearset inside thr tranny and a bad driveaxle. it took about 7 hours to do it but i wouldn't even attempt it unless you have knowledge of auto transmissions
Old 09-15-2005, 11:03 PM
asemstr asemstr is offline
Re: 99' Whinning noise
First check your tires for cupping and uneven treadwear. What speed range is it most noticable? Does it occur mainly during accellaration, coasting (check in drive and neutral!), cruiseing under throttle, or all of the above? Any vibration or frequecy change based on wheel and driveline speed?
IS IT FIXXED YET?!
