Old 06-14-2005, 12:01 AM
hardcorejuggalo hardcorejuggalo is offline
Send a message via AIM to hardcorejuggalo
Question Quick audio question
Hey whats going on i have a quick question for yall.
I have Two Ample ACWD 12 inch woofers heres their specs: Dual 4 ohm voice coils 250 rms 500 watt max.
Now i have a Ample amplifier specs according to the box: 600 watts bridgeable 150 rms x 2 4 ohms, 450 rms x 1 4 ohms, 240 x 2 2 ohms
Is it possiable to run these two subs off this amp or should i just keep it as a speaker amp and go spend the money on another bigger amp
Its a Juggalo Thing MCL
Old 06-14-2005, 01:30 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah dude, that stuff should work out just peachy. When matching subs to an amp, you want to match the rms power handlings of each. I would wire your two subs to 4 ohms (if you need a wiring diagram I can ge you one) so you will be putting 450 rms into two subs that can handle 500 rms. Sounds like a good deal to me. 450 rms is a good ammount of power... it will shake your car pretty good. Anything more powerful will result in shitty sound and possible blown speakers.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-14-2005, 03:51 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I always "over power" my speakers ......... my 2 300 watt (RMS) subs are being driven by appx 1000-1100 watt (RMS)
Old 06-14-2005, 07:37 PM
Re: Quick audio question
thats awsome yeah if you could help out with the wiring it would be great thanks man.
Old 06-14-2005, 07:56 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
1200w going on an 800w RMS 18
Old 06-14-2005, 11:25 PM
bronxblaza117 bronxblaza117 is offline
Send a message via AIM to bronxblaza117
yea i wanna learn how this stuff works so can u post the diagram in an attachment so i can see to...thanks
Old 06-16-2005, 12:57 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Actually your wrong...... how a sub will sound from the power is totally enclosure dependant. A sub will sound the same regaurdless of power (only louder with more)( unless your clipping). Blown speakers happen from simply putting too much power into a driver (usually much more then the rated rms with clean power playing music), Clipping close to at or above rms severly enough to prohibit proper cooling of the voice coil, or mechanicaly over driving the speaker making the coil bottom out and not get adequate cooling from motion. You can also mechanically overdrive a speaker, but that is install and power dependant. Distotion (shitty sound) comes from clipping or mechanically over driving a speaker. The enclosure also has a lot (most actually) to do with how a driver sounds.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 06-16-2005, 01:00 PM
Audio Guy
go to jl audios web site, they have a really good tutorial on wiring up subs to amps
