Go Back   Automotive Forums Car Chat > Ford > Probe
Old 06-13-2005, 08:04 PM
kjvirgin kjvirgin is offline
Question OD Light Blinking/ Trans Fluid Leaking HELP!
94 Probe SE w/Automatic Transmission. OD light just started blinking but OD still worked, tranny shifting normally, cruise control cruised. The next day drove 100 mi home from coast, OD worked, tranny shifted normally & cruise cruised. Got 1/2 mi from home w/smoke coming from engine compartment and tranny fluid leaking below. What could be my Problem? Need Suggestions Soon!! Thankyou.
Old 06-16-2005, 02:18 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: OD Light Blinking/ Trans Fluid Leaking HELP!
Something as large and off as this isn't something that i can tell u to fix, nor should u, or larger problems are going to happen. The best bet in this case is take it to your local garage, and properly get it fixed, or its just going to get worse.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 06-16-2005, 05:28 PM
NemesisGT NemesisGT is offline
possibly front seal on tranny for the leak... as for the smoke from engine... i would also suggest going to your local garage or dealer to have it looked at. that major engine damage and i would not suggest fixxing this by yourself
