Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-13-2005, 07:46 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Performance cams w/ turbo??
I was looking at Skunk 2 stage 2 cams or Buddy Club 3 cams on my 99 B18C1 GSR. I am planning on eventually turboing my GSR and i am buying mods accordingly.
I was wondering why i can't use a normal VTEC performance cam, and instead i have to buy a specific turbo cam. What would be the difference between the two???
Thanks
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 06-13-2005, 10:56 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
the turbo cam probably has less overlap between the intake and exhaust valves.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-16-2005, 12:00 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Performance cams w/ turbo??
i suggest you install the cams and turbo at the same time, doing one without the other may hurt preformance(IE - using turbo cams with no overlap on a N/A engine will decrease low end torque.)
Old 06-16-2005, 08:33 PM
Schister66's Avatar
AF -Advisor
No i wanted to buy like a Buddy club 3 or Skunk 2 stage 2 cam, but i forgot about all the valve overlap. I was going to get a set of NA performance cams and put them on my car which will eventually have a DIY turbo kit on it. I didn't realize, because i wasn't thinking at the time, that you couldn't use NA cams on a turbo set up. I got it now......thanks everyone!!
