Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-13-2005, 06:45 PM
milo42 milo42 is offline
Send a message via MSN to milo42
Question 1996 Ford Explorer AC problems
I have a couple of problems with the AC. First one is where is the automatic temperature control sensor. I read in another post that it is located in the center of the dash. Does anyone have any specifics? Also, when going to charge where is the low line connector. I have a 96 Explorer EB with the 5.0.....thanks for any help
Old 06-13-2005, 07:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1996 Ford Explorer AC problems
If I may ask, why do you think it needs charged? There are various other problems that can cause a non-cooling condition.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-14-2005, 08:11 AM
In response
If I could find the automatic temperature control sensor, I was going to check it first, and then charge after that. I was having intermittent problems with the climate control, heat and air unpredictable and now no air at all. thought it could be a combination of things
Old 06-14-2005, 01:27 PM
way2old's Avatar
TOKEN HILLBILLY
Ford's manual says it is behind the top center of instrument panel. It should be close to the 4X4 mode switch in the dash. The diagram does not show a really good location. The module itself is the complete EATC control head in the dash.
Old 06-18-2005, 11:01 AM
chr97 chr97 is offline
Well my experience with the blasted thing was 350.00 a husband who wouldn't stop and listen. It started with my heater in the winter, it would not blow if you shut the door to hard it would kick on. It was like sitting next to a radaint heater. Then summer came around and the ac of course does the same thing. Low and behold it took my husband not paying attention hitting a raised railroad track at 45. worked ever since. I have had to had it recharged once my experience with that it it still blows it just does not cool. A mechanic friend told me that A/C and the heater work together it uses he A/C to pull the moister out of the air when it heats. I don't know any truth to that but obviosly something works together on them.
Old 06-20-2005, 04:08 PM
anthony1978 anthony1978 is offline
Send a message via Yahoo to anthony1978
low pressure is the small line coming from the ac acumalator
