Old 06-13-2005, 04:41 PM
Biggins2121 Biggins2121 is offline
Send a message via AIM to Biggins2121
more tail trouble
Ok to sum it up my left tail light woulnd not work when i turnd on my headlights at night so i replaced the bulb socket. It workd fine for 2 day s now everytime i turn my signals on they both flash and when i press the brake they stop. Any ideads on what this could be?. So when i turn left and have my signal on for left they both flast, same when i turn right. They look like my hazords flashing but my hazords airnt on. Thanx for any and all help guy Ken. Also my sterring colume move up and down alittle if that helps.
Old 06-14-2005, 10:51 AM
JA no Y's Avatar
JA no Y JA no Y is offline
The steering wheel moving up and down is from either loose or worn out bolts in the steering colum it self. You'll have to take the steering wheel off to get to those bolts to tighten them. Its not easy without a steering wheel puller and a lock plate removal tool.
As to why both turn signals are working when you turn the left on....Have you checked the flasher? And make sure you wired the plug correctly.
Old 06-14-2005, 11:12 AM
chris15706 chris15706 is offline
Re: more tail trouble
There is a ground light that hooks from your chassis to your tail lights, make sure that is still connected.
Old 06-15-2005, 12:41 PM
ok yeah i checkd there connected right and as for the ground can u tell me where on the chas. its located. Also I just replaced the whole steering colume. Since the front lights work and everything i think that a wire is touching some place on its way 2 the back. Cause all the wires in the front are connectd fine, because the fronts work fine. So yeah if anyone can tell me the path that the wire runs it would save me some time and I really appreciate it. Thanx all Ken
Old 06-15-2005, 02:56 PM
Its no further than a foot from your whole tail light assembly. You will see a lone wire that comes out from the rest of the loom.
