Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-13-2005, 04:21 PM
tylera23 tylera23 is offline
rear end?
there is a noise, when i drive , i think its the rear end.... any thoughts or comments,...
Old 06-13-2005, 05:58 PM
steve11 steve11 is offline
Re: rear end?
there were some 2003-4 that had bad clutch in the posi-trac rear alxes, if you have that. also, have been some rear alxe bearing problems. you might ask dealer about service bulletin if this is newer model.
Old 06-13-2005, 07:12 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: rear end?
Is there anyway you can describe the noise? Is it a noise on turns, speeding up, slowing down, steady cruise.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-13-2005, 09:44 PM
its a 96 eddie bauer, v8 , it happens mainly when pressing the gas pedal, and while cruising.....
Old 06-14-2005, 11:43 PM
exploded99 exploded99 is offline
Re: rear end?
I assume you are refering to a whining noise? Not a rumble, grinding or other type of noise?
A whine would be typical for a rear end. Transfer cases can also whine. Have your fluids checked.
If you have any small shops in your area that specialize in differentials or four-wheel-drive shops they will usually look at it for free and give you their opinion. They are quite a bit cheaper than Ford dealers.
Look under axles in the yellow pages.
Old 06-15-2005, 01:32 AM
well took it to the shope, its gonna cost $1,200 to fix, shoulda listened to dad and kept the 2wd vehicle on the street and not had fun in the woods...
Old 06-16-2005, 10:08 PM
Wink Re: rear end?
Depends on what kind of fun you had.
