Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-13-2005, 03:40 PM
ice745 ice745 is offline
AF -Advisor
Suspension sound..
I recently started drivign with the windows down, since its summer. And I also haven't had the music on either. But now that I can hear the engine noise and such, I noticed my suspension is making a noise. I am not sure if its normal, nor how long its been doing it. If I hit a good enough bump, like usually potholes that have been filled yet still have that dip to them, the suspension goes in fine, but then when it pushes the wheel back down it makes a clanking kind of noise at full extension on the right side. I recently had a "camber adjustment bolt" on the same side, I don't know if thats causing it.
Thanks for any tips.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 06-13-2005, 06:45 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Suspension sound..
If you have a '97 or so Camry, they have a problem with the strut tower mount.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R.'s Avatar
Resident Chemist
If you have a '97 or so Camry, they have a problem with the strut tower. Search this forum.
Old 06-13-2005, 07:54 PM
AF -Advisor
I forgot to mention, thanks, its a '94 4 cyl Camry.
Old 06-13-2005, 10:57 PM
Brian R.'s Avatar
Resident Chemist
Probably a loose suspension part somewhere. Check the lower and upper strut bolts for tightness, also the sway bar ends and support bushings. Could also be a worn suspension component such as a lower ball joint or tie-rod end, etc. Have it looked at by a competent mechanic if you can't find an obvious loose bolt.
