Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 06-13-2005, 02:17 PM
jbrig jbrig is offline
sunroof drainage holes???
Still getting water on the floor behind the passenger seat. Already cleaned out the front drainage holes, but cannot find rear ones.
Are there rear drainage holes/lines for the sunroof? If so, where do they terminate?
Thx
Old 06-15-2005, 10:44 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
They are at the rear lower sill pannel of the rear doors.
Have you checked the body plugs under the car.... remove them and see if water comes out.
ALso check the rear window seal.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 06-16-2005, 10:37 AM
Yes, I found the 4 plugs under the car and took them out, but no water came out.
When you say "rear lower sill panel", are they actually on the doors, or in the door frame area?
Thank you,
Old 06-16-2005, 07:36 PM
VDUBMAN
Should be on the bottom of the door frame "body side" where you kick your feet off when theres snow on it before you get in the car in winter.
