Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-13-2005, 01:23 PM
Bluesax Bluesax is offline
OBD Code P0304
99 Rodeo, had engine code read and it came up P0304, cylinder 4 misfire. Question. Should I start with the plugs/wires first? Buddy says it's "all oxygen sensors." What is the best way to proceed?
Old 06-13-2005, 01:37 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: OBD Code P0304
If you have over 50k on the plugs then yes replace them (search the board for more info, Isuzu's only like certain brands).
No wires to replace.
You could also, switch the coils around to see if the misfire moves to a different cyclinder. If so you have a bad coil
If non of this helps:
One common cause for a misfire code is due to a leaking intake manifold gasket. (see the FAQ's).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
