Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-13-2005, 12:22 PM
InTeGrA421 InTeGrA421 is offline
Send a message via AIM to InTeGrA421
Tach and speedometer NEED HELP
hey guys i got a question
ok its a 2000 wrangler cj
heres the problem....when driving yesterday, the speedometer and tachometer stopped working. The car ran fine, but the tach and speedomoter were both at zero and not working. Would this be a problem with the fuses possibly?? I dont know a whole lot about electrical, so does anyone have ideas of what the problem could be??
thanks in advance
Old 06-14-2005, 11:46 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Tach and speedometer NEED HELP
99 and 00 models have that quirk sometimes. Assuming the gauges came back, first place to check is all the connections going to the cluster, under the dash.
If they stayed out, then check fuses.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-15-2005, 10:53 PM
JeepinGirl JeepinGirl is offline
Send a message via Yahoo to JeepinGirl
My 1999 does that. It's a wire inside the dash. I just hit the top of the dash when I need to know how fast I'm going...otherwise I dont' worry about it.
Old 06-16-2005, 07:47 PM
CanaMark CanaMark is offline
just start hitting the thing. otherwise get a GPS unit and stick it on dash. i go by feel so I dont need tach to change gears. I am a canuck (canadian) I go by Km/h, my jeep is american imported to canuck land. I can judge speed accurately, but I need a new speedo. I am buying a GPS, sticking it right in center so I can see it clearly. I also think it will be good for the trails. I will be buying a top of the line model. Also having a digital readout of speed reduces my chances of getting ANOTHER speeding ticket. Another thing to add on my rig is cruise control, another cheap add on to control my heavy foot.
Old 06-17-2005, 05:53 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Sorry to poke fun, but wow, I didn't know jeep was making a CJ again. You drive a TJ dude.
Cj wasn't built after 1986
Yj wasn't built after 1995
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 06-22-2005, 12:34 PM
montana_griz montana_griz is offline
Re: Re: Tach and speedometer NEED HELP
Wire inside the dash? Grounding wire? Power wire? Did the dealer tell you this or have you been able to repair it once? I think this is a widespread problem with Jeep products as I have read (and am having) the same problem on a 98 Jeep, and the 97 was recalled for bad grounding to the dash.
Old 06-25-2005, 02:56 AM
Bad grounding really messes things up. Cuases alot of mysterious things to happen. Pull the dash and make sure all ground wires are securely mounted.
Old 08-02-2005, 12:34 PM
pat8942 pat8942 is offline
It could be the printed circuit you will have to pull the dash and check continuity from the plug to the tach and speedo connections.
Old 08-05-2005, 01:09 PM
89ltd 89ltd is offline
could be the speed sensor,
