Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 06-13-2005, 11:54 AM
tenisbum589 tenisbum589 is offline
engine swap
right now i have the stock 5s-fe engine in my 91 celica gt, and im looking in to swaping it with a 3s-gte, the only one i can find right now is a MR2 Turbo MK2 3S-GTE 90-93 - Engine, 5-Speed Transmission, Computer (JAS-3SGTE-A), my question is will the 3s-gte for a Mr2 fit on my celica gt
Old 06-13-2005, 11:33 PM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
Re: engine swap
check ebay tey have quite a few 3sgte engines or search google there not hard to find check the read if you want tyo do the 3sgte swap section if you have questions.
Old 06-15-2005, 01:56 AM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
Re: engine swap
it should fit. But question is, do you really have the money and time for it?
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 06-15-2005, 07:09 AM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
it will fit, but it would be a tight fit
it will cost quite a bit, there are alternate trannys that you could use if you dont feel like doing the mods to the mr2 tranny, alot more work
Old 06-15-2005, 02:21 PM
Re: Re: engine swap
i will have the money for it soon, the engines ive been finding look reasonably priced, the thing thats going to take forever is finding either the manual Mr2 tranny, or the v6 camry tranny, and once i get all that im upgrading the stock turbo, which all means that this is just one big money pit, cause ill soon need to buy an upgraded clutch,(looking into the stage 2 performance clutches for mr2s and celicas) but once its all done my car will be much much faster, so i think its worth both the time and money
Old 06-18-2005, 03:51 AM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: engine swap
your looking at low 14's high 13's at best with the swap tho, and btw yes you can use your mr2 tranney he only things that need to be changed is take(or cut out) all the shift linkage from ur current 5sfe (or all trac) shift linkage and transferr it over to the mr2 tranny, no the mr2 e-153 tranny linkage wont work with ur car so itll need to be swapped over, and btw you can still use ur 5sfe tranney
