Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-13-2005, 08:30 AM
3.0maxima 3.0maxima is offline
Unhappy '03 I35 not responsive..
Hello,,
My i35 is acting up, I got into my car in the morning today, started the engine and and noticed that mu dashbord lighted up with "warning lights" (check engine, SLIP, ABS). For second I though that it will go away, so I have put the car in reverse pressed on the accelerator, but the car goes in idle ??? (won't go over 1500rpms),it almost look like the throttle does not response to accelerator, ECU went bad?? turned off the car waited 2min and tried again, but no change, I just washed the car on saturday (but it was fine bk then), regular wash @ home, I did not go to work today because of this problem, please advice....
Thanks..
Old 06-13-2005, 11:59 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: '03 I35 not responsive..
Originally Posted by 3.0maxima
Hello,,... "warning lights" (check engine, SLIP, ABS)... I did not go to work today because of this problem, please advice....
Thanks..
Your car is possibly in safemode, ECU limits rpm to crawl. That happens when/if MAF or cam pos sensor is bad. (Still ABS/slip does not fit in there.) Open close sensor connectors...
How about voltage at battery?
Did u also wash engine? Pls, never use water in computer centers...
Is there any change after engine warmup? If its only COLD, points to TPS (water?).
...Self diagnostics...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 06-13-2005, 02:42 PM
Post Re: '03 I35 not responsive..
there was no water in the engine compartament, just the outside
Old 06-13-2005, 06:39 PM
I have connected that code scanning tool and i get P1222 2times
P1226 2times
all together i see 4 codes, checked connections, fuses, when I started car no response from o2 sensor nor evap sensor, will keep on looking..
Old 06-13-2005, 07:33 PM
Unhappy Re: '03 I35 not responsive..
typo in previous post, the codes were
P1122
P1126..
Old 06-14-2005, 03:55 AM
Re: Re: '03 I35 not responsive..
P1122
P1126..
- 1122 is throttle ctrl function =TPS (see FSM p.473 and forwards)
TPS is a resistor; even new resistors may be bad and break anytime as all human made tingies... Its structurally the same as this and may be DIY repaired. Easy and relatively cheap to replace (90$?); click on: http://www.cardomain.com/ride/748507/6
- 1126 points to a relay in this circuit. Knock on the relay with the screwdriver head -or- replace. Relay location is seen on p.484
Btw. Those codes fit with your description - which is not always the case.
Edit: "I have connected that code scanning tool ..." Did u buy that, how much??
Old 06-14-2005, 07:52 AM
Thumbs up Re: '03 I35 not responsive..
You can buy that tool for $180 @ AUTOZONE(they do have cheaper one for $80), but I rented it for them for $180, but will get all my $ back once tool returned (got 30 days)...
Where is the relay again??
"Relay location is seen on p.484 Btw" not sure what BTW is..
Will do that once I get home today..
Thanks again,,
Old 06-14-2005, 09:51 AM
...Where is the relay again?? "Relay location is seen on p.484 Btw" not sure what BTW is.....
Hello? Btw is not BTW and not was even written on the same row... By The Way...
U have the downloaded manual, do u? Open, scroll to page EL-484 and view that (bad) drawing, then try to locate relay under THE hood... sorry cannot do that for u. In the manual there is somewhere also a locator page for all these lidl boxes... dive in.
...It pay$ to read once the whole manual through...
Old 06-20-2005, 03:47 PM
lil754boy lil754boy is offline
Send a message via AIM to lil754boy Send a message via MSN to lil754boy Send a message via Yahoo to lil754boy
Re: Re: Re: '03 I35 not responsive..
What manual are you all referring to. I am looking for a manual for my I35 now. Who has a good one. The haynes from Autozone suck. Not enough detail.
Old 06-21-2005, 05:20 AM
Re: Re: Re: Re: '03 I35 not responsive..
FSM.
On this thread tHeres a word: INFO
Seek out...
