Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-13-2005, 01:56 AM
fchanes fchanes is offline
Idle spike at start and shifting
I thought I'd run this by the group. 93 V6. When I start the engine(hot or cold), the rpm's spike above 2000. This also happens when I shift from park to R and to D. Any thoughts? I know this to be odd because I have two 93 V6's and the other is normal. It's just a spike. Thanks.
Old 06-13-2005, 03:23 PM
ice745 ice745 is offline
AF -Advisor
Re: Idle spike at start and shifting
When I first start my 94 it goes up to like 1500, and going into R or D goes up to 1200, higer if A/C is on. I don't know exactly why it would go up to 2000 tho. I think the spike is somewhat normal, but 2000 seems high.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 06-15-2005, 03:18 PM
don24mac don24mac is offline
Vacuum leaks will do that. I'd check all the hoses for cracking or for any hoses that may have been displaced. Also check/replace the PCV valve and hose. Although a dirty PCV valve usually causes hesitation, sometimes the hose can be loose fitting or cracked.
