Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-12-2005, 11:01 PM
chancereid chancereid is offline
Send a message via MSN to chancereid Send a message via Yahoo to chancereid
95 Contour SE Odd Trouble Codes
I have a '95 Contour SE, in relatively great shape. But the check engine light just won't go away. I am reading the trouble codes stored in the PCM and come up with 117 (ECT below minimum voltage) and 217 ( PCM detected coil 3 primary circuit failure) and 232 (PCM detected coil 1,2,3 or 4 primary circuit failure).
I replaced the coil pack and still the same trouble codes, even after clearing the PCM and the KAM codes.
If anyone has any suggestions that may help, I am open for business.
Thank You,
Chance
Chance T. Reid
Grants Pass, OR
1995 Ford Contour SE
Fully Loaded - Leather
2.5L V6 Auto w/OD
4 Wheel Disc w/Anti-Lock
