Old 06-12-2005, 10:16 PM
terriblenone's Avatar
terriblenone terriblenone is offline
E-Brake light staying on...
I cut a corner the other day and bumped the curb with my back wheel at about 7mph. the e-brake light came on after the wheel got bumped. How do I turn the light off? I've tried just putting the ebrake on and releasing it like normal, but no luck so far. can I reach under the car and tap something to get the cable back to full slack? The e-brake doesn't feel like its actually on at all, just the light is.
This happened to me during the winter when I slipped into the ditch going pretty slow, and it ended up just turning off by itself after a day or so, but this one's been on for a couple days now.
Nate
My 1989 CRX Si
Old 06-12-2005, 10:36 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: E-Brake light staying on...
that light is also for your brake fluid, check that. If the fluid is fine the emergency brake switch is located on the brake lever.
Old 06-12-2005, 10:45 PM
no, I bumped something in the wheel when I hit the curb, because the light came on at the same instant. its not the fluid, and its not that the ebrake lever isn't getting enough travel to give thce cable slack, but I'm guessing something in the drum got tapped.
My 1989 CRX Si
Old 06-12-2005, 11:00 PM
Forunn Daberator
Slack is in the cable has nothing to do with the light, its done by the tilt of the lever. Sence the lever is all the way down and the light is still on and it came on when you hit something you should check the fucking fluid.
Old 06-12-2005, 11:01 PM
the fluid's fine.
My 1989 CRX Si
Old 06-12-2005, 11:02 PM
Forunn Daberator
GOOD!
Old 06-12-2005, 11:11 PM
holy crap, what's your problem?
My 1989 CRX Si
Old 06-12-2005, 11:38 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
He is right, it should be 1 of those 2 problems. Or maybe your float in the brake fluid is messed (or the wires). Check a manual and you'll see this page (shifted slightly to fit as a smaller image, but all the info is there): http://img.photobucket.com/albums/v4...brakelight.jpg
Old 06-13-2005, 01:16 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
theres only two things that make the light come on. and both have been mentioned.
the sensor on the ebrake handle. which will work even if the cables are disconnected from the handle.
the float sensor in the brake master cylinder. this can get stuck down, even if the fluid is full.
the only thing i can think of is that you hit the curb, and it pinched off a brake line, causing a fluid loss. or, it pinched it off while you were braking, and its keeping the fluid from returning to the master cylinder.
or just dumb luck and one of the sensors broke at the same time that you hit the curb
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-13-2005, 05:56 PM
Forunn Daberator
Re: Re: E-Brake light staying on...
I like yelling, some people think its sexy.
Old 06-14-2005, 01:20 PM
Juicy05 Juicy05 is offline
Way sexy....
