Old 06-12-2005, 08:28 PM
omaro86 omaro86 is offline
What next??
Alright Iv'e had my car for almost 5 months now... So far I have got
-K&n fipk
-3sx downpipe
-ATR dual exhaust
-HKS SSQV bov
-Accel 8mm Wires
-Greddy MBC (14psi)
-Greddy turbo timer
What would be some good next upgrades, keeping in mind this is a daily driver?? thanks in advance.
Old 06-12-2005, 09:49 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: What next??
so are you saying that you don't want it to take down your gas mileage???
Also are you looking for a visual or performance upgrade???
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 06-12-2005, 10:21 PM
Hotshot8792 Hotshot8792 is offline
I would probably say a lightweight flywheel/upgraded clutch combo.
Now if you dont mind spending a grand, a carbon fiber driveshaft is an awesome upgrade to AWD cars.
If you want to stick with something simple, go with a 3SX lightweight pulley.
If you want something a little more complicated, you can always go with a slight turbo upgrade such as 13G's or 13T's in which you can get the turbos for probably under a grand, slightly used.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-13-2005, 01:29 AM
Re: Re: What next??
I wouldn't mind a little loss in milage, but nothing drastic. and I'm mainly going for performance unpgrades right now though.
I was already planning on a clutch, and maybe 13g's. For 13g's would I need to do anything fuel related??
Old 06-13-2005, 04:28 PM
Igovert500's Avatar
blue + red light magnet
Re: What next??
Yeah, I would say clutch next. Then start saving for fuel/turbos. Personally, I'd go with DR500s instead of 13Gs...slightly bigger, and I think cheaper...but check that, I might be wrong.
Anyway, fuel related. You will probably want the Walboro pump, and you may want to hotwire it...although it may even be possible to get away with simply hotwiring the stock pump....I'd get the Walboro, even hotwired, I don't think it will outrun the fuel pressure regulator...so why not?.
Injectors...you would need 450cc probably. You can get them used off a DSM. Then just have them cleaned up/flow tested.
And then a fuel controller. Probably SAFC/SAFC II
Lastly, get a datalogger if you have an OBDI or hybrid. If not, a wideband o2 would be a good idea. As you want some idea of knock or actual A/F ratios.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-13-2005, 08:25 PM
but get an upgraded clutch before you upgrade turbos, or you may find your clutch slipping quite a bit
Old 06-14-2005, 05:41 PM
Re: Re: What next??
I was thinking about 13g's... I don't know much about the dr500's but ill read up on them.... Thankx
Yeah, I'll have a clutch pretty soon..... I was thinking about Spec stage II or rps street max, anyone have any experience with them??
