Go Back   Automotive Forums Car Chat > Honda > RSX
Old 06-12-2005, 07:30 PM
sgt d sgt d is offline
Question cold air vs. short ram
What is the difference between a cold air intake system and a short air ram system? What are the pros and cons to each one? thanks....
Old 06-12-2005, 08:45 PM
sivic02's Avatar
sivic02 sivic02 is offline
Re: cold air vs. short ram
Ram air is a shorter tube than cold air. The cold air intake tube runs further away from the engine which lets it suck up colder air. Both will give you a few extra hp, you will probably get a couple extra hp out of a CAI, the only downside to the CAI is since it sits fairly low to the ground if it get completely submersed in water it can lock your engine up. Its hard to submerge your entire filter in water but its happened to people before.
Here's to being single, seeing double, and sleeping triple
Old 06-13-2005, 09:37 PM
crazy_canuck crazy_canuck is offline
Short ram is easier to install; cheaper; and won't get hydrolock.
Cold air gets much better gains; does not suffer from heat soak; but there is a possibility of hydrolock.
I had a huge list of it on ClubRSX, when I find it i'll post it.
Old 07-03-2005, 05:38 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
you could buy a by pass valve and if the hole filter goes under the bypass valve will protect you from that
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 07-04-2005, 02:48 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
still a bypass valve wont guarantee your car from hydrolock. It has happened to my friend before (in this case he didnt have a bypass valve) but its not hard to get the filter completely submerged in water it just depends his car was lowered so may be that could have been a factor. Just becareful around places with lots of deep puddles then youll be ok. Still get the bypass valve though its definitely worth the money.
Old 07-05-2005, 09:42 PM
I'm not even sure if the bypass valve fits the RSX....I can't remember now but I know there is a reason why there isn't really any RSX owners with the bypass valve.
Old 07-06-2005, 01:28 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
To me a short ram intake is a stock intake with an open filter. The HP gains from a short ram are usually because of the better filter that is out on. Just avoid driving in deep waters and you should be fine with a true CAI.
Old 07-09-2005, 01:47 AM
I had one on my rs and i drove my car through puddles all the time and never had any problems also my car was almost on the ground so i know that they work really well
MODS
