Old 06-12-2005, 03:39 PM
kd3yt kd3yt is offline
Send a message via AIM to kd3yt
Code P0122 Throttle Position Sensor
2001 Blazer TrailBlazer options 58000 miles
Had a post earlier today where I reset the ECM and then had low idle/stalling. That problem cleared up after a short drive. Then had to take my daughter home (about 30 miles). While driving there the SES light came on. After I dropped my daughter off, went to Autozone and they read my codes - P0122 Throttle Body Sensor input voltage low. They cleared the code and I drove home and the light did not come back on. Question is: Could this have been caused by resetting the ECM and the low idle for few miles after resetting?? The vehicle is driving fine, no rough idle or surging. How can I test the TPS?
Old 06-13-2005, 12:50 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: Code P0122 Throttle Position Sensor
Back probe dr blu wire. {.47 volts } Throttle closed. As you open throttle voltage should go up to close 5 volts.
Dr blu wire at tps sensor.
