a/c break down
hello
who can tell me what i have to do to check the climatisation on my TS 92, I just get hot air when I switch on cold air!!!!! thank's |
Re: a/c break down
Does the A/C clutch try to engage when called for?
You may just need a recharge. |
Re: Re: a/c break down
ok
how do I know when the a/c clutch engage is there a special noise? Thank's |
Re: a/c break down
You should hear a click as well as hear the engine idle speed change slightly when it engages due to the extra load.
Re: Re: Re: a/c break down
Best regards Mathias |
Re: a/c break down
If you get HOT air when you switch to cold, I'd look for a problem with the diverter door acatuator.....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Bonjour
Can you tell me what is the diverter door acatuator. Is it inside the car ( les commandes de circuits ) Merci de la réponse Paul |
Re: a/c break down
Yes..inside...well hidden. Photos here from Bonneville, but similar in transport manual.
www.avigex.ca/xport/MixerDoor1.jpg www.avigex.ca/xport/MixerDoor2.jpg Instruction for access to actuator (Transport manual): Remove instrument panel upper trim pad assembly REMOVE OR DISCONNECT: -headlamp and wiper switch assembly screws -cluster tim panel screws -side window defogger grilles -screws retaining IP trim pad -open glove box -screws retaining IP trim pad -I/P trim pad from seated position and from vehicle
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 06-15-2005 at 04:56 PM. |
what a job to reach the actuator door!
Re: a/c break down
IN fact I did remove that trim pad a few times to access and remove the instrument cluster some time ago and it is quite easy. But I had not checked for access to the diverter door actuator at that time.
