Old 06-12-2005, 12:08 AM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
Zc Motor ?'s
i WAS WINDERING IF THE 86-87 INTEGRA ENGINE IS THE SAME AS THE 88-91 CIVIC ZC ENGINE? iS IT THE SAME, AND IF IT IS, WILL IT JUST FIT RIGHT IN AND DOES IT HAVE THE SAME HORSE POWER?
4TH GEN CIVICS ROCK
Old 06-12-2005, 03:01 AM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
similar... yes, same... no
the closest thing the
86-89 integra motors is the brown top zc
the integra motors correct me if im wrong put out under 110 hp
the black top zc's put out 130hp
The integra motor will bolt directly up, i dont even think you have to swap some wires on the distributor.
hope this helps,
-Wes
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Old 06-12-2005, 06:51 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Re: Zc Motor ?'s
hope this helps,
-Wes
Wrong,Wrong!!
The 86-89 Integra motor puts out 118 HP
The 86-89 Integra motor is NOT a ZC motor, its a D16a1.
The 86-89 Integra D16a1 will NOT bolt into a 88-91 Civic/CRX. The mounts don't even come close and the 88-91 trannys will not bolt to the D16a1 block.
The 86-87 D16a1 will fit in a 85-87 Civic/CRX that has a MPFI motor(Si)
90 Civic Si Turbo ZC
Old 06-12-2005, 11:52 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
If you wanna learn more about the zc motor, heres a good source.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-12-2005, 02:44 PM
Re: Zc Motor ?'s
i didnt say the integra was a zc, they are similar
reread the post
90-91 B18a1
Revo Short shifter
Short ram intake
2 1/4 exhaust
Old 06-12-2005, 02:46 PM
Re: Zc Motor ?'s
and the d16a1 will bolt up ITS THE SAME BLOCK AND MOUNTS ... I know this b/c i have done the swap several times, i have owned an 86 crx, 88integra 89 civic si, two 91 crx si's a 93 integra a 95 civic dx, a 93 civic dx and i have done swaps on all of them and some experitmenting wiht ls/vtec and also goint with a boosted ls
also i do swaps for people for money, i have done a total of 23 swaps up to this date
90-91 B18a1
Revo Short shifter
Short ram intake
2 1/4 exhaust
Old 06-13-2005, 01:15 AM
duffman868 duffman868 is offline
Re: Zc Motor ?'s
the a1 will not bolt up to the 2nd gen crx but it will bolt up to the 1st gen crx. so if you did the swapand it bolted right up than you either swapped an a1 into a 1st gen or swapped a zc from a 2nd gen teg into a 2nd gen crx
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 06-13-2005, 01:42 AM
Re: Zc Motor ?'s
Alrite, thanks fellas.
4TH GEN CIVICS ROCK
