Old 06-11-2005, 06:38 PM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
backfire and sputters
well my friend just put in another dx motor in his beater.. but the motor seems to be missing and it backfires a whole lot... dizzy and spark is all good... we're thinking it might be the camshaft on it... any clue? need some help here...
Old 06-11-2005, 06:46 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: backfire and sputters
Sounds like its out of time.
Old 06-11-2005, 06:58 PM
out of time?? the timing on it is perfect.. he put his timing gun on it and still does the same thing with the timing on right..
Old 06-11-2005, 08:13 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Does it actually start up, and are you getting any codes?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 06-11-2005, 10:41 PM
ATMDC's Avatar
ATMDC ATMDC is offline
hey dont mean to jack your thread or anything, but i didnt want to waste bandwith posting like the same question, my friends car just broke down yesterday cuz of the same problem, but now his doesnt even start no more it just sputters and back fires, i think its the timing, you think so? it was a new motor, a d15b but the car seemed to be running fine before it happened.
Old 06-11-2005, 10:43 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Check rotor in dizzy didnt come loose
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 06-11-2005, 11:56 PM
ATMDC's Avatar
it starts for like 2 seconds then conks out, still check the rotor?
Old 06-12-2005, 06:40 PM
ATMDC's Avatar
sorry i do not mean to post again but its important that i know this as soon as possible before my friends 4g gets towed!!
Old 06-12-2005, 06:55 PM
4G4D Store's Avatar
Ya, I'd check the rotor
Old 06-12-2005, 06:57 PM
ATMDC's Avatar
ok thanks i'll do that
Old 06-12-2005, 06:59 PM
4G4D Store's Avatar
Another thing I'd check on the dx motor is the cap - check the pin that goes into the dizzy - it has a tendency to break of during isntallation - I've seen that cause the car not to start, or barely start and stuff like that.
Old 06-12-2005, 10:20 PM
ATMDC's Avatar
u talkin bout the pin in the connector hooked to the dizzy?
Old 06-13-2005, 01:20 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
he means the carbon button in the center of the dizzy cap. they break off sometimes if you dont install the cap straight.
you guys keep thinking ignition timing, but havent considered firing order or cam timing. if the firing order is wrong, it may still run but will backfire.
also, the timing belt may have jumped a tooth and the cam timing is off. the car will still run with 1 or 2 teeth jumped, but it will run like crap. remember all those fancy adjustable cam gears that everyone buys but leaves at the default position?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-13-2005, 11:03 PM
my friends firing orders are the same... i mean he's a mechanic he's been workin on hondas for at least 3 years now and this is the first time i seen him get stuck... timing is right, spark wires in position, what seems to be the problem?? distributor?? manifold??
Old 06-13-2005, 11:37 PM
ATMDC's Avatar
ok i got ya i understood it by carbon button, but anyways i wanted to say thanks alot from everyone, had the car up and runnin in about 15 minutes, svaed my friend a tow fee, and i got me a free reace at the indoor kart racing track lol, thanks guys, the little screw fell out of the side of the rotor making the distributor shaft just spin on the inside of it
