Old 06-11-2005, 05:09 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
Two Cable's Behind Stock Radio?
Sup guys,
I pulled out my stock radio/tape head unit out of my 99gs spyder today and notice that there are two cable aside from the harness and the antenna what are these for?
I believe one might be for a cd changer, the other I have no clue, can anyone help me out with this? Im throwin in a pioneer head unit.
Thanks
Old 06-11-2005, 05:17 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Two Cable's Behind Stock Radio?
if i can remember correctly, there is one for cd changer, one for power antenna and one for the stock amp. or maybe the cd changer plugged into the amp and there was just a cable for the amp and antenna....can't remember exactly, but you can't just 'hook up' a pioneer head unit to our cars...you have to bypass the amp and do a shitload of rewiring.
Old 06-11-2005, 11:34 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Well you got farther than I did. I was wondering how you got the dash apart to get the stock head unit out? I tried for hours to find where all the screws/bolts were, and could not get it apart. I ended up having it done by professionals, and they charged me a shit load, and I still don't know how to do it. Anybody got a good diagram or something of where all the screws are and the best way to do it? Or just explain where they all are, that would help too, for future reference.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-12-2005, 12:02 AM
nova1313's Avatar
nova1313 nova1313 is offline
Dash is simple. Pull off the face plate around the stereo use a scrw driver it pops out when you pull up. 1 screw and two pop rivits on each side of the console. 2 in front one next to your seat (just pull this comes out then), next you can see the mounting screws for the stereo on ach side. I took out the pocket first 4 screws. Then 4 for the stereo it's not too bad. But I had the same problem as you the first time.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 06-13-2005, 08:21 AM
toicy4ya's Avatar
Re: Re: Two Cable's Behind Stock Radio?
Yup its simple just like Nova said. Except the center console for the 99 spyder might be slightly different. After popping out the face place around the stereo, in order for you to remove the center console you need to remove a total of six screws. Two underneath the radio face plate which you just popped off (easily viewable), two on each side of the center console towards the rear near the bottom and two underneath the cup holder/ashtray (need to pop up the cup holder/ashtray in order to get to it). Once the screws are removed you can shimmy off the the console. Lastly you need to remove the plugs connected to the lighter. Thats it!
btw, you can install a aftermarket head unit without all the re-wiring and it will work fine. I installed a Pioneer DEH-P8600MP head unit myself simply adding a Mitsubishi Eclipse radio harness. Once I installed the harness to the Pioneer Radio all I had to do was snap it into the factory harness and your done.
However, one thing I did notice and i believe its a common problem with 95-99 eclipse owners when replacing the stock head unit with an aftermarket, the tweeters do not work. Im sure there is a way around it, Can someone give me feedback on this?
Old 06-13-2005, 11:39 AM
I was wondering that also, which was why I thought about splitting the wires going to the front speakers with the tweeters in the dash. Does anybody think this is a good idea?
'92 3000gt SL
Zoom Stage 1 Clutch
Old 06-14-2005, 11:22 PM
crazzyguydj's Avatar
crazzyguydj crazzyguydj is offline
Send a message via AIM to crazzyguydj
In my 1g I split the wires going to my dash speakers with tweeters I put in the back of the compartment under the cd player. I guess that would be basically the same situation you are in but I don't know what tweeters you are talking about.
My first car! blue 93 plymouth laser 5 speed <Wrecked!>
My second car! red 93 mitsubishi eclipse 5 speed
3rd car (soon to be) Golf tdi 03 or 04 havent found one yet
