Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-11-2005, 03:30 PM
hondaEX77 hondaEX77 is offline
Lightbulb boost a H23 or swap or a jdm h22
hey, im trying to figure out what im gonna do with my car. its an SI so its got an H23. and i was thinkin it cost a little more to boost than to do an engine swap. but what do you guys think would be better, this car will be a everyday driver. either boost the H23. or get a JDM H22. keeping in mind this car has to be reliable so i can drive it everday
thanks
Old 06-11-2005, 07:41 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
A turbo would obviously make your car go a lot faster than a motor swap, but the turbocharged motor won't last as long. It can still be reliable, but like I said a N/A motor would last longer than a turbocharged one in a Honda. Instead of JDM H22 why not just get a USDM one because there isn't much of a hp difference unless your thinking about the Type S swap.
Old 06-11-2005, 08:53 PM
what would be the difference between a Type S and a JDM.
Old 06-11-2005, 09:04 PM
ludeguy ludeguy is offline
Re: boost a H23 or swap or a jdm h22
believe it is 220 (type S) vs 200hp (reg jdm). not sure on tq numbers.
yea unless you plan on building your bottom end etc, i'd go for the jdm swap - it's a cheap way to gain 40hp, and you can even use your h23 trans making it cheaper.
I swapped a jdm h22a into my 4ws lude, and love it - i'm thinking of boosting next spring, once i'm all researched up - i'll prob buy a second h22 for the build up tho.
all the best.
Old 06-12-2005, 11:26 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
This topic has been covered numerous times, but it really depends on your budget. The H23 is better for boost, and as long as you do it right and tune it, it will be very reliable. It all depends on your goals and your wallet.
