Old 06-11-2005, 02:57 PM
automan25 automan25 is offline
brake caliper torque setting
What is the torque setting for the bolts that hold the brake caliper in place. This is on a '99 3.8 with ABS
Automan25
1999 Intrigue GL
3.8 litre engine
Old 06-11-2005, 09:34 PM
crlogic crlogic is offline
TORQUE SPECIFICATIONS Application Ft. Lbs. (N.m)
Brake Hose-To-Caliper Bolt
Front Calipers 40 (54)
Rear Calipers 32 (44)
Brake Line Fittings (Tube Nuts) 11 (15)
Caliper-To-Bracket Bolt
Front Calipers 63 (85)
Rear Calipers 32 (43)
Caliper Bracket-To-Wheel Carrier Bolts
Front Brackets 137 (185)
Rear Brackets 92 (125)
Parking Brake Cable Guide Mounting Bolts 18 (25)
Parking Brake Lever Mounting Nuts 18 (25)
Power Brake Booster Mounting Nuts 20 (27)
Proportioning Valve Caps 20 (27)
Rear Wheel Hub Mounting Bolts 55 (75)
Wheel Lug Nuts 100 (140)
Application INCH Lbs. (N.m)
Caliper Bleeder Valve
Front Calipers 115 (13)
Rear Calipers 97 (11)
Parking Brake Bracket-To-Support Plate Bolts 89 (10)
Parking Brake Indicator Switch Mounting Screw 26 (3)
Transmission Filler Tube Bolt/Screw 115 (13)
