Old 06-11-2005, 02:55 PM
cnilkyrclit cnilkyrclit is offline
brakes
hello all, my 03 alero needs new front pads. my question is how difficult is it to change the pads. i also have a 93 lumina eurosport, and pads are fairly easy to change. thanx
Old 06-11-2005, 04:14 PM
biv343 biv343 is offline
Re: brakes
If you've changed pads on the Lumina, you can do it on the alero - same concept, loosen the two bolts that hole the caliper to the spindle, remove the caliper, remove the old pads, compress the piston back into the caliper, assemble in reverse order (to quote the Chilton's books...)
Old 06-11-2005, 04:18 PM
Re: brakes
thank you very much
