Old 06-11-2005, 11:41 AM
Tsipowered Tsipowered is offline
Send a message via AIM to Tsipowered
Question trouble with a 16g turbo
i had a 16g turbo installed on my TSi and the original vacume tubes going to the turbo and to the stock intake bracket when hooked up like the stock turbo created insane amount of boost right away and ended up blowing vaccume lines off the engine. So the mechanic drilled into my stock intercooler pipe and t'ed off one of the lines can someone please help me fix this problem cuz now with a new 16g turbo my car is slower than ever i hope this can easily be renderd. it also seems like it only has horse power between 3000 and 4800 im lost and pissed off
HELP MEEEEEEEEEE
97 TSi AWD 5 speed
Old 06-11-2005, 02:01 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
cant you just redue the original lines and then throw in a boost controller...?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 06-11-2005, 04:26 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: trouble with a 16g turbo
i dont understand a word you are saying. You installed a 16g and no boost controller, blew off a pipe, and took it to a mechanic that obviously knows nothing about turbo cars? Now you have the wastegate actuator hooked up to some random place in the IC piping? Fire your mechanic, get a boost controller, and hook it up to the intake manifold again (jake will say turbo). Fix the intercooler pipe hole, and make sure you aren't running enough boost (boost gauge?) to lean out and blow the motor. What mods do you have? If none, why is there a 16g on it?
Old 06-12-2005, 10:59 AM
mods are HKS BOV and Apexi Turbo timer Apexi N1 full exhaust i have gauges A/F and Boost gauge just no pillar or any clue where or how to hook them up. And another question will ford racing injectors work in the TSi fuel rail they are i belive 30# injectors, and i have a 4 bar fuel pressure regulator from bosh that i have from my corrado which i never installed all products are new in box just need to know if they are good for the TSi motor
97 TSi AWD 5 speed
Old 06-12-2005, 12:29 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Just a hint of advice, dont buy parts then ask questions later. Do the opposite of that
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 06-12-2005, 02:23 PM
i never bought these parts for this car i had these from a previous project thats where the question came from so read before you comment about this im asking if the injectors and fpr will work to help my already fucked up problem from stupid mechanics. now im taking the project on myself
97 TSi AWD 5 speed
Old 06-12-2005, 02:31 PM
JoeWagon's Avatar
Banned
If you can't hook up a boost gauge, please don't attempt to rig parts that aren't made for our cars. Start at the beginning again, and keep that 16g on stock boost until you have a logger.
Old 06-12-2005, 05:34 PM
i know how too hook it up but im not sure of everything that needs to be done i have found a site that will clear everything up but i just wanna know if i need bigger injectors and fpr?
97 TSi AWD 5 speed
Old 06-12-2005, 05:48 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
putting on the 16g and having this problem seems to me that it problem was going on befor this.heres a link that should solve any problem with vacume lines.
http://www.taboospeedshop.com/emissions.htm
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
