Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-11-2005, 08:32 AM
teemsta teemsta is offline
wheres the fuel filter?
can anyone tell me where i can locate the fuel filter? zj running terrible after it is on the road for a while. runs fine for the first few miles.
thanx
Old 06-11-2005, 01:00 PM
a_alyte a_alyte is offline
Re: wheres the fuel filter?
I'm not sure what year ZJ you have, but my '98 ZJ has a fuel pump located inside the fuel tank.
You should buy a Haynes or Chilton's manual from your local autozone or somewhere, there just good to have!
Old 06-12-2005, 11:01 PM
ooops sorry, i have a 94 jgcl 5.2 looking to replace fuel filter, is it with the pump in the tank?
Old 06-12-2005, 11:15 PM
Ron68 Ron68 is offline
Re: Re: wheres the fuel filter?
The filter on the 94 is not located in the tank. It is on the frame, on the driver's side, forward of the tank. The in-tank filter/pump assy wasn't installed until 96 or so.
2004 Grand Cherokee Overland (DD)
2000 Ford Explorer (Daughter's ride)
1986 Ford F-150 ( Ridge Runner)
2002 Mercury Mountaineer (Mama's ride)
1968 Ford Mustang Coupe (modified a little)
"If it ain't broke, then don't fix it."
Old 06-15-2005, 02:59 AM
ramairgto72
Guest
Posts: n/a
I think the wose thing they did was put it in the tank, my 93 is outside and my 02 and 98-5.9 is in the tank, they say you dont have to clean it in the book, but I would feel better if I could.
Old 06-15-2005, 06:29 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
There is a little bit of a difference in the way the old fuel systems and the new "demand delivery" fuel systems work. The old systems would recycle fuel up to the engine and back to the tank via the pressure regulator if it wasn't used. Now, only fuel that is actually going to be used is pumped through the filter and out of the tank. This makes the filter last much longer...Theoretically as long as the pump.
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 06-15-2005, 10:54 PM
ramairgto72
Guest
Posts: n/a
I was able to get a Pontiac 400 from my bud that got it from on down the line, it had never been opened, and by god the fuel pump look and was crusted on like it was the orignal, and just for kicks I put it in the vise and used a pipe on it and it worked, tho I have no idea the pressure it was pushing out, however it was still working.
I know first hand about pumps in the tank idea, they do go bad. It just seems a better Idea to have it on the outside, along with the pump.
Old 06-15-2005, 10:55 PM
ramairgto72
Guest
Posts: n/a
SteveB05, your rad, is it a factory replacement? Who makes it?
Thanks
Old 06-16-2005, 01:15 AM
SteveB05's Avatar
CSF aftermarket, but factory mounts...
http://www.radiatorinfo.com/radiator...r/catalog.html
I was gonna post a pic on the other thread but I have to take one first. I'll still do that when I can.
Steve
Old 06-17-2005, 12:10 PM
ramairgto72
Guest
Posts: n/a
Thanks for the info, i'm not sure but I think that the place I had my skids put on may have damaged the bottom of my Rad, I was happy to see the 360 and 318 are the same.
Did it bolt right in? any problems at all?
Old 06-17-2005, 07:54 PM
SteveB05's Avatar
Everything lined right up...not mods at all.
Steve
