02' Sunfire
Drivers side power window:
Window will not go down all the way,and when trying to raise window,it only goes up @ 2-3" at a time... I'm thinkin it may be the motor,but was wonderin if anybody else has had this problem. Not too bad when it's nice outside,but a real PITA when it starts rainin
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Re: 02' Sunfire
It could be a worn or bad motor but it could also be the window regulator needing lubrication. Take the inside panel off and lubricate the regulator. If it is dry then you should see a marked change. If the motor is bad then you will already have it apart to do the repair.
