Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 06-11-2005, 01:17 AM
SHORTYBOY113 SHORTYBOY113 is offline
Whats Next
I Have A 91 Turbo. I Have Exhaust, Intake, Ct20b, 3" D/p, And Running 15 Psi. I Just Got Money For Graduation. I Have 1800 Dollars To Spend On Parts. What Should I Get Next. I Want To Get A Greddy I/c, Ats T/b Inlet, Clutch/flywheel, And Upgraded Fuel. Any Input Would Be Nice.
CARDOMAIN.COM/ID/MR2_SEXY11[color=red]I DONT NO HOW TO ADD IN A PIC SOMEONE TELL ME.[IMG]car pix 009[/IMG]
Old 06-12-2005, 07:22 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Whats Next
I would suggest:
*GReddy IC with 2 SPAL fans (one push and one pull)
*the Manj Shroud for the GReddy IC
*the ATS TB Inlet
*water injection
I would not bother with clutch/flywheel unless your is bad.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 06-12-2005, 11:46 PM
MR2turbo93's Avatar
MR2turbo93 MR2turbo93 is offline
Re: Whats Next
What about a water sprayer for the IC? i know they work wonders on the WRX's and EVO's what about on a MR2? If you have a pusher and puller fan, can you use a sprayer or will they get ruined in the water? Also do you hook the fans to a switch or the factory sensor?
"In Reality we have this thing called physics. Respect it, or it will kick your ass."~ Dave Coleman
Old 06-13-2005, 05:01 AM
AF - Advisor
Re: Whats Next
I have my fans hooked to the factory sensor, but I have a switch for the sensor. One way on the switch shuts the sensor off so the fans come on. The other way the sensor is on and decides when to run the fans.
As for a water sprayer for the IC, sure they are fine. However, if you are going to go through the trouble of setting a system to spray water, why not spray it into the engine where it will offer some huge benefits?
Also, most tracks are not going to be happy with you spraying water outside the engine.
Old 06-13-2005, 02:21 PM
MR2turbo93's Avatar
Re: Whats Next
good point, i want water injection but was not sure if you could benifit from the having the sprayer too.
Old 06-13-2005, 07:50 PM
Mobit Mobit is offline
Send a message via AIM to Mobit
wow
That's exactly what I'd do in that position as well, however in my case I'm not looking to really ever exceed 15psi so I'd probably ditch the water idea. I really love the feel of a car with a sportier/light flywheel, although if it's your daily driver and you see a lot of traffic...I'd say stick with stock heh.
Old 06-19-2005, 03:41 PM
Re: Whats Next
how much does the sprayer cost. and why not a spearco i/c.
Old 06-19-2005, 04:24 PM
AF - Advisor
Re: Whats Next
The Spearco is much better than the GReddy, but unless yo uare looking for more than 300 rwhp ... I do not think it is worth the extra $$$
If you were looking for more than 300 rwhp, you should not be going with the CT20B.
Old 06-21-2005, 01:01 AM
Re: Whats Next
well i just got the ct20b just to hold me off. i had 176k on the ct26 and i needed to get rid of it. i want to go with as much power as posiable. i just started workin full time cause im outta school. so money is not realy a big issue any more. i still want to play it smart. how much does the spearco cost. i never found it on a website for the 2. do u no what the power difference is in the greddy and the spearco. what can the boost how between the 2.
