Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 06-11-2005, 01:14 AM
LPC LPC is offline
Question 96 Gmc 1500 Help!!!
96 GMC 1500 - STARTS BUT WON'T STAY RUNNING
parts replaced: ac delco fuel pump, fuel regulator, distributor cap, rotor button, wires & plugs, temp. sending unit.
starts, runs for 5-10 seconds, can't accelorate, and dies. try again-does samething over & over.
fuel pressure reading between 55-65 at all times
WHAT THE HELL IS THE PROBLEM?????
ANY IDEAS????
Old 06-11-2005, 08:01 AM
MrBillPro MrBillPro is offline
Re: 96 Gmc 1500 Help!!!
What about fuel filter?
Old 06-11-2005, 10:40 AM
LPC LPC is offline
Re: Re: 96 Gmc 1500 Help!!!
Fuel Filter Has Been Replaced 2 Times During This Problem. If U Can Think Of Anything Eles Please Let Me Know Thanks
Old 06-11-2005, 05:00 PM
flair666369 flair666369 is offline
Send a message via Yahoo to flair666369
not to insult you, but did you check for any OBD codes? or check the vaccuum system?
Old 06-11-2005, 09:44 PM
LPC LPC is offline
Not Insulted At All.thanks For The Help.
Scan For Codes With Obd1.
Passed No Codes. I Have Tryed This 3 Or 4 Times, On Codes. Checked All Over No Vac. Leaks. Replaced Crank Post. Sensor Also No Luck Still Having Same Problem
Old 06-11-2005, 11:56 PM
shell1990 shell1990 is offline
Whats the mileage, it could be the fuel injectors
Old 06-12-2005, 12:05 AM
70camaro 70camaro is offline
Is '96 OBD 1, or OBD 2? My 97 is OBD 2, maybe you got the wrong scanner?
Old 06-12-2005, 12:30 AM
they started OBD II mid 95 i beleive, so it should be OBD II, a chiltons/haynes manual should say for sure. Remember the three basics for "fire" is fuel/air/spark(ignition). Compression is a key role too for engines. Unfortunately sensors or as i like to call them, "pain in the *ss sh*t that gets in the way", have just as big of an effect, but rule out the four basics first.
Old 06-12-2005, 01:25 AM
I'm an idiot, there is a haynes manual sitting right next to me, let's take a look see, shall we?......
TROUBLESHOOTING
Engine starts but stops immediatley......
1-Loose or damaged wire harness connections at distributor, coil or alternator.
2-Intake manifold vacuum leaks. Make sure all mounting bolts/nuts are tight and all vacuum hoses connected to the manifold are attached properly and in good condition.
3-Insufficient fuel flow.
(again, spark/air/fuel)
FUEL PRESSURE
V6 and small block V8 engines ..... 60 to 66 psi
7.4 V8 engines ......................... 56 to 62 psi
FUEL INJECTOR RESISTANCE
Central SFI systems (V6/V8) ...... 1.37 to 1.36 ohms
MPFI systems (7.4L V8) ............. 11.4 to 12.6 ohms
Did you check to see if fuel was actually coming out of the injectors?
If you have any other questions that I can look up in my book, give me vehicle specifics and ask, and i'll see what I can do.
Note: I've read elsewhere on this site (I forget where or for which application of truck) that the aftermarket fuel pump had insufficient power/pressure. OEM pump from the dealer worked, this might be the case, but from the sounds of it probably not.
Old 06-13-2005, 09:03 PM
LPC LPC is offline
TROUBLESHOOTING
FUEL PRESSURE
the fact that it runs tells me their is fuel coming out of the injectors
Old 06-18-2005, 11:22 PM
CobraCDN's Avatar
CobraCDN CobraCDN is offline
Send a message via Yahoo to CobraCDN
Any idea what the Resistance should be on my TBI Injectors (1992 GMC 2500,4x4, 350) Thanks
