Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-11-2005, 12:07 AM
sellncars's Avatar
sellncars sellncars is offline
Send a message via AIM to sellncars Send a message via Yahoo to sellncars
Ignition system questions?
Hello everyone,
I have a 92 Bonneville SE with a 3800, i had a problem with a code 41 " Cam sensor circuit " the car would also stall and sometimes not start at all, just turn over and it had no spark. After about 5-6 times of no spark condition it would finally fire. The car stalled while driving also, i replaced the crank sensor & cam sensor they were cheap enough and the car has 160k. Stalling while driving had stopped. No start condition also had stopped. Now i still after clearing the codes get the SES light on once in a while " code 41 again " I went to the junk yard and grabbed a PCM switched the prom and reset the computer again after driving it for a day. Code 41 came back, anyone thinking ICM? Any help will be greatly appreciated. The car runs great by the way, just that damn SES light.
Thanks,
Sellncars
1999 Chevy Malibu, 3100V6 VIN J with 73,000.
1997 GMC K1500 EXT cab, 350 Vortec with 164,000
Old 06-11-2005, 10:17 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Ignition system questions?
The ICM is a good guess but I would also check the wiring to the cam sensor. You may have a loose connector or a wire that is rubbing and making contact causing it to throw the code.
