Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-10-2005, 09:24 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Any sort of Adjustment: Gas Gauge???
Hi all again.
I learned the hard way that in my 84 Caprice when the gas guage is at 1/8 a tank... its really empty. Car died while I was on my way to the gas station. Anyway, is there any way to adjust the guage so when the guage says I have 1/8 tank left, I really do have some gas left? Thanks!
Old 06-10-2005, 10:18 PM
CD Smalley CD Smalley is offline
Re: Any sort of Adjustment: Gas Gauge???
It will require alot more work than it's probably worth...
But taking the tank down and adjusting the float using a trial and error process..... How many times are you willing to find yourself stranded and out of gas???
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-11-2005, 08:46 PM
PeteA216's Avatar
If thats the only way, I think I'll just fill up before a quarter tank. Thanks though, I was just wondering if there was some sort of adjustment outside of the tank.
Old 07-05-2005, 07:51 PM
TommySS TommySS is offline
Check the sending unit wire connection to see if it's corroded.
Removing the tank isn't difficult, but it should be empty and you should have a buddy assist
Old 07-05-2005, 09:34 PM
jd74 jd74 is offline
Send a message via AIM to jd74
usually you can replace float or entire sending unit in tank . sending unit can be expensive. floats are cheap. if you take sending unit out try cleaning it with electrical parts cleaner
Old 07-09-2005, 10:41 AM
Incitatus's Avatar
Incitatus Incitatus is offline
That's a fairly common problem. There are products such as Gas-Rite that may fix that.
Also, here's a write up on the Impala SS forum that may help.
(Sorry, no pictures in the write up
A big fan of the big sedan.
Old 07-10-2005, 12:25 AM
PeteA216's Avatar
Wow! Thanks! My car does suffer from both problems mentioned in the forum. I'm definately looking into getting this.
