Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-10-2005, 09:05 PM
rusty1701 rusty1701 is offline
'94 Jimmy a/c question ( have checked threads)
I just did a r134 retro ( have done on other cars). The system has the correct amount 134 per gauge. When the engine is at idle, the compressor is on for about 20-30 sec(maybe longer), then off for about 10 sec. When i hit the gas, it kicks in and out about every 3 secs. I have checked other threads and I haven't had any luck! Thanks in advance.
Old 06-11-2005, 06:42 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: '94 Jimmy a/c question ( have checked threads)
Sounds like you're still low on pressure.
Old 06-12-2005, 06:09 PM
I used three cans of 134/oil/sealer combo!!! It does blow cold, not ice cold air. As I mentioned the gauge does show the coorect amount of charge. If I add some more will I cause any damage. Should I try some 134 by itself? Would the amount of oil left in the system plus the oil/sealer in each can take up too much space? I guess that would change the pressure wouldn't it? Is there any component that would cause the problem?
Old 06-14-2005, 04:01 AM
maddog245 maddog245 is offline
I just had my compresser replaced yesterday. They drained the system and oiled the new compresser on the left side valve. Then the tech told me it held just shy of three can's so you could have too much in it. Watch it don't blow the seals on the compresser.
Maddog
Old 06-14-2005, 06:48 PM
Crap, I sure hope that is not the case!! Could there be a problem with the pressure switch? I wonder what size cans of 134a were? Was it r134a or did they use r12?
Old 06-14-2005, 09:23 PM
Thumbs up Re: '94 Jimmy a/c question ( have checked threads)
It's ok old boy. They were the small cans and done to spec. My latest problem is that I am installing the overhead console and am unble to dertermine what the 15 pin Yellow go's to, I have all the other's. I think!
I am about over this tread of consoles. Someone, ANYONE just give the directions. ( I am willing to help) Rift I will help if I can!
Thanks
Maddog
Old 06-14-2005, 09:28 PM
Re: Re: '94 Jimmy a/c question ( have checked threads)
Also
They have a die in the gas now days so they put a lite on it and wear glasse's to see where the leak is. So if it is in your system they can see it. got it?
Old 06-15-2005, 02:44 AM
DelCoch's Avatar
DelCoch DelCoch is offline
You probably didn't loose very much oil when you did the retro. Therefore, you may have too much oil and not enough freon. The symptoms you stated are typical of low freon.
Put a jumper across the terminals of the pressure switch, (don’t leave it there very long) and see if the symptoms go away. As a general rule, when the pressure switch goes bad, the compressor won’t run at all.
The only way to get excessive oil out of the compressor is to take it off the engine and dump it out.
DelC
Old 06-15-2005, 06:48 PM
i think I will just start over with a totaly empty system. I just checked and the kit I bought has the dye, but I could not find any glasses. Thanks for everyones input!!
