Old 06-10-2005, 09:03 PM
nfg2184 nfg2184 is offline
How often do you clean the intake filter?
I've had my weapon R short ram for about 4 months and havent cleaned it, and its startin to look pretty dirty. Should I clean it yet? And how should I do it, just basically take the filter part off and rinse it with a hose? Wouldnt there be some risk of getting water sucked into the engine? Should I leave the filter off for a couple hours to make sure it completely dries or something?
-2004 Cavalier LS
Mods:
Weapon-R Short Ram, Shift Kit, Nitrous Express Wet Kit, Upper/Lower mounts.
Audio:
15" RE .SE sub to BRUTUS 1500, 6.5" RE components in the rear, Apline's in front, all to Pheonix Gold Profile, Alpine deck.
-1997 Sentra XE, 5-speed POS, commuter.
Old 06-10-2005, 09:08 PM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Dont know how the weapon R stuff works but I dont think its as simple as water and dry and yes the filter must be 100% before you put it back on.
I only go AEM and I always use the recharge kit for the AEM filters. You may want to find out or Im sure someone that knows on here will tell you if the W/R filter needs oiled or not cause Im not sure. Frankly I hated oiling my AEM filter it took forever and took too much time. First time I did it I over oiled the hell out of it and spent like 3 hours letting the filter bleed out the access oil.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 06-11-2005, 12:18 AM
BorgKing's Avatar
BorgKing BorgKing is offline
Just use the K&N cleaning + oiling kit (recharge kit). Basically you brush off excess gunk on the outside, then spray / soak in the cleaning solution. Then rinse from inside out and lastly apply oil. Simple, but yea, I also over did the oiling part and had to let the excess flow out.
Old 06-12-2005, 04:17 AM
Re: How often do you clean the intake filter?
About how often do you guys clean yours?
-2004 Cavalier LS
Mods:
Audio:
Old 06-12-2005, 04:54 AM
PsychoJJ's Avatar
When ever I change my oil. I like to do it as a habbit like that so I dont slack off and next thing I know Im losing power and gas milage. That and I drive in alot of heavy construction areas so it gets pretty dusty.
Old 06-12-2005, 10:40 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Um...or you could just put in a real K&N and never have to change it for about 100,000 miles.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
