Old 06-10-2005, 06:28 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
starter question...
OK, 92 talon Tsi 5spd. My problem is that it will start soumetimes no problem and sometimes not at all. Also after being ran for a bit and you shut it off it does not want to start. I pulled it off and took it up to autozone and had them test it and everything checked out a ok. What could be going on? Bad connection mabee? oh and when it has a hard time starting after being ran it kinda stutters and clicks.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 06-10-2005, 10:41 PM
macder macder is offline
Send a message via MSN to macder
Re: starter question...
When you try to start it does it crank and not fire? Please describe all the symptoms. My guess is far fetched, but maybe it's your starter. See if it will start up everytime by kick starting it(Rolling the car in neutral w/ignition on to about 5mph, put into 2nd gear and release clutch). Please don't kick start it in 1st gear, this can mess up timing.
Besides that, the basic checklist for no-start would be as follows
-Check fuel injection system
-Check fuel pump drive control system
-Check power transistor
-Check power to ECU
-Check control relay
-Check fuel injectors
-Ensure fuel pressure is correct
-Check for contaminated fuel
-Check for vacum leaks
-Check for malfunctioning ECU
-Check for open or short in wiring and/or poor connections
Hope that helps you somewhat.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-11-2005, 10:53 AM
irupp33's Avatar
Whops what i forgot to add was that i pulled the starter of and took it to autozone. Thats where the problem is with the starter. Other than that car runs perfect. I get weird noises from the starter but they say everything is fine with it. Im thinking it could just be a bad connection somewhere.
1991 Eclipse GS-T
Exterior: stock
Old 06-11-2005, 11:38 PM
Where are you located? I have a few spare starters that I'll let go for chunk change.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 06-11-2005, 11:56 PM
irupp33's Avatar
go tit fixed. I went and got a new starter from the junkyard and put it on and still nothing so i took it to discount and they tested it, It was shot, so i went back tot he junkyard and they swapped it out and the one i got works fine. The first one was on its way out.
1991 Eclipse GS-T
Exterior: stock
