Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-10-2005, 04:14 PM
FJRocha FJRocha is offline
Question Diferential gears swap
Howdy,
I have an '02 Suburban 1500 2WD (LT Autoride), I might want to use it to pull a 7500# trailer. I know this might be pushing the burban a bit, but since a new truck is out of the budget, I am thinking to change the stock diferential ratio to a 4.10 ratio and gain some margin.
Any suggestions?
Old 06-12-2005, 08:25 PM
Pamsdad Pamsdad is offline
What gear are you currently running? Tire size?
5.3/6.0/8.1?
97 Chevrolet CC Dually
00 Blazer
Old 06-13-2005, 10:28 AM
Engine is 5.3 liters. I believe the tow rating for this burban is 7400# using the standard diferential ratio. I want to convert it into 4.10:1 ratio. I figured it should be a lot cheaper than a new truck.
Old 06-13-2005, 10:31 AM
Re: Diferential gears swap
Also, the tires I got are Michelin Cross Terrain 265/70-R16 (Standard size)
Old 06-14-2005, 04:57 PM
Lightbulb I found it.
I found what I needed to do the swap:
http://www.accuautoparts.com/axledet...d=MOT:GM95-410
