Old 06-10-2005, 03:11 PM
Slabjack Slabjack is offline
Fuel Problem
Hi,
I have an 86 Ford F-150 that is dumping fuel in #8 cyclinder.
I replaced the EEC computer and still the problem is there,also replaced a burned wire leading to the computer still nothing.Replace two fuel injectors samething nothing.
Maybe someone could give me advice on what is wrong.
Oh I should mention the truck turns over but won`t start.
Thank you
Old 06-10-2005, 09:59 PM
mustangmike351c mustangmike351c is offline
what do you mean by dumping fuel. is the plug not firing or the injector not pulsing
Old 06-10-2005, 10:37 PM
Re: Fuel Problem
Well when I try to start the truck up,it will turn over (not start) I do get a good spark. then it binds up after a couple of turns.
When I removed the spark plug the cyclinder it is full of gas.
I am not sure if the injector is pulsing or not
How do you check it(I am no mechanic).
Thanks for the reply
Old 06-11-2005, 08:30 PM
Re: Re: Fuel Problem
have you changed spark plugs? you may have some internal damage. bent valve or something. do a compression check.
Old 06-11-2005, 10:40 PM
Re: Re: Re: Fuel Problem
I will try changing the plugs & also do a compression check.
It could be internal there is 300,000 miles on the truck.
Thanks for the advice mustangmike351c.
Slabjack
